wat is Checksum error
Jul 15th, 2008
Hi...!!! i was uprading UC 6.0.1 to 6.1.2..now wat happened was the PUB worked fine but when i started on the SUB it gave the following error:-
07/15/2008 16:18:36 upgrade_manager.sh|./RedHat/APPRPMS/cm-ccmhelp-1.1.0.0-2.i386.rpm failed checksum|<LVL::Error>
07/15/2008 16:18:36 upgrade_manager.sh|Unmount DVD/ISO|<LVL::Info>
07/15/2008 16:18:36
Can anyone help me wit this???? thanks a lot
tim.giles Wed, 07/16/2008 - 05:14
I seems as though the upgrade is failing as the subscriber cannot verify the integrety of the files (via the checksum).
Have you tried upgrading via the CLI??
Please rate post...
vegardkjer Tue, 07/29/2008 - 05:28
hi.
i'm having the same problem as you.
did you find a solution to this problem?
