07-15-2008 05:23 AM
Hi there,
Can an ASA have both its inside and outside interface in the same Area 0, same OSPF instance?
If I place the ASA in transparent mode will OSPF work OK through the ASA?
Many thanks
Wayne
Solved! Go to Solution.
07-15-2008 05:41 AM
An ASA can have both its inside and outside interface in the same Area 0, same OSPF instance.
OSPF will work ok through the ASA in transparent mode. You need ACL for permitting OSPF.
07-15-2008 05:41 AM
07-15-2008 06:05 AM
Thanks for the clarification.
Wayne
