IPM 4.0.1 issue when adding devices in sources devices
rherve
When I add devices as sources devices, 'collector mgmt' 'devices' i check the box 'All devices' and then clic to 'Add devices', i arrived on the next page, there is no equipement to select ? why ?
Finaly I used the CiscoWorks Assitant to add devices in IPM, he say me that the devices successfull added to IPM... but there is nothing.
When I look in targets devices I see all the equipments
It is necessary to have RW community configure in DCR CS ?
Can I used IPM just to check and IP SLA counters configure on devices, or IPM has necessarily to send the configuration to the equipment ?
Hervé
akemp
Level 5
Level 5
Do you have either rtr enable or ip sla enable on all of your devices ?
Dont use assitant for IPM, use IPM to add devices.
You need to have the RW string and IPM needs to push the configs.
