How can i do?
Jul 15th, 2008
Good Day, I am currently working on a proyect integration of video on my current IP platform, this is to bring real-time video of one building to another, I know of Certain Rules Relating to perform this Interaction but not all, is that Phase I create a VLAN for the video and provide QoS on the other for the delay is the minimum but not as I make this configuration,
Any suggestions or advice will be helpful
Thank you
Paolo Bevilacqua Tue, 07/15/2008 - 09:21
hi, if you have gigabit linking switches, don;t worry too much, video will work fine in any case, no matter the vlan, etc.
aalvarez150210 Tue, 07/15/2008 - 10:05
thanks for your answer, but I truly constraints banwhitd as to reach the building must pass through a building using intermediate SDH as transportation equipment, if you have some material that I can help with setting what thank you
Thank you very much
Paolo Bevilacqua Tue, 07/15/2008 - 10:22
Ultimately, what is the speed of the circuit linking buildings, and what exact model of switches or routers do you have ?
aalvarez150210 Tue, 07/15/2008 - 12:42
The speed that I have is the link of 90Mbps, but is shared, we only have STM-1 (SDH Frame) of which we use 2 Vc-3 (VC-3 for each 45Mbps) which reaches the intermediate node, and is downloaded and placed back into the network to reach next node (Node end). The Equimet involved in this link are Central Core 4500, intermediate 3550 and end 4500 (after going there to a floor of this building which ends in a 3550 on a link to 100Mbps
thanks for your attention!
aalvarez150210 Tue, 07/15/2008 - 12:52
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(35)SE5, RE
LEASE SOFTWARE (fc1)(Intermediate)
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version
12.2(25)EWA2, RELEASE SOFTWARE (fc2) (Principal and End)
