SNMP v3 - Error in Authentication password
Answered Question
Jul 15th, 2008
Im trying to configure snmp v3 on a 2960 switch (IOS 12.2(44)SE. I use the following commands:
snmp-server group mygroup v3 priv
snmp-server user myuser mygroup v3 encrypted auth sha myauthpass priv aes 128 myprivpass
I then get the error message:
%Error in Authentication password
Any ideas?
Cheers,
Ben
Correct Answer by Joe Clarke about 8 years 8 months ago
When you specify the "encrypted" keyword, you need to specify the password in an encrypted string. It doesn't look like you want this. Try:
snmp-server user myuser mygroup v3 auth sha myauthpass priv aes 128 myprivpass
Overall Rating: 5 (1 ratings)
David Stanford Tue, 07/15/2008 - 07:45
  • Cisco Employee,
Looks like you need to specify a read or write view
Syntax for the group name :
snmp-server group [groupname {v1 | v2c | v3{auth | noauth | priv}}]
[read readview] [write writeview] [notify notifyview] [access
access-list]
snmp-server user username [groupname remote ip-address [udp-port port]
{v1 | v2c | v3 [encrypted] [auth {md5 | sha} auth-password [priv des56
priv password]] [access access-list]
misd.network.support Tue, 07/15/2008 - 07:59
Thanks for the reply.
As I understand the syntax in [] is optional. I tried specifying a readonly view by changing my group command to:
snmp-server group mygroup v3 priv read readonly
I still get the same error message. Interestingly if I drop the optional "encrypted" keyword from the snmp-server user command, it does indeed create the user. The user doesn't appear in the config - but a show snmp user does list it.
Cheers,
Ben
Correct Answer
Joe Clarke Tue, 07/15/2008 - 07:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
