Warning message
6509 CaTOS Policing question
Jul 15th, 2008
All,
We have a 6509 with Sup720 running 8.6(4). We configured two GigE port 2/13 and 2/14 as trunk allowing VLAN 101.
We want to apply a policer to limit traffic on 2/13. Below is what I did:
set qos enable
set qos policer microflow MIC-P1 rate 100000 burst 100 drop
set qos acl ip IP-ACL3 trust-cos microflow MIC-P1 ip any any
commit qos acl all
set qos acl map IP-ACL3 2/13
Then I inject 500Mbps traffic on both 2/13 and 2/14, and I get 500Mbps traffic out of both ports too. It seems the policing on 2/13 does not take effect. Can anyone help me out?
Li
Marwan ALshawi Tue, 07/22/2008 - 03:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
compaire ur conffig with the following config
CAT6500-CATOS> (enable) set qos policer microflow ONE-MEG-FLOWS
rate 1000 burst 8 drop
QoS policer for microflow ONE-MEG-FLOWS created successfully.
Rate is set to 992 and burst is set to 8 in hardware due to hardware granularity.
CAT6500-CATOS> (enable) set qos acl ip ONE-MEG-FLOW-ACL dscp 0
microflow ONE-MEG-FLOWS ip any any
ONE-MEG-FLOW-ACL editbuffer modified. Use 'commit' command to apply changes.
CAT6500-CATOS> (enable) commit qos acl ONE-MEG-FLOW-ACL
QoS ACL 'ONE-MEG-FLOW-ACL' successfully committed.
CAT6500-CATOS> (enable) set qos acl map ONE-MEG-FLOW-ACL 3/1
ACL ONE-MEG-FLOW-ACL is successfully mapped to port 3/1.
if helpfule Rate
good luck
lizhu2008 Tue, 07/22/2008 - 05:42
I finally know why it did not work before: microflow polcier only affect traffic routed by MSFC, I need to use the following command to make my configuration work:
set qos bridged-microflow-policing enable
Thank you for your reply,
Li
