Recover deleted flash in PIX
Jul 15th, 2008
I mistakenly deleted the only *.bin file in my PIX 525. How canI recover it?
I am able to load the image from Monitor mode to ram, but when I am not able to tftp the bin to flash. By the way, the PIX is a seconday PIX.
srue Tue, 07/15/2008 - 12:40
  • Blue, 1500 points or more
what OS version?
you should be able to tftp back to the pix if its up and running.
sightlay8 Tue, 07/15/2008 - 20:39
I cannot put ip address to none of the interfaces. I think because this is a seconday PIX or failover only PIX.
srue Wed, 07/16/2008 - 05:49
what version OS is/was installed on it?
take it offline or if it's currently a standby pix then make sure secondary addresses are defined for at least one interface on the primary. then use this interface to copy the OS up to it.
sightlay8 Thu, 07/17/2008 - 12:07
I fixed the problem. I was not able to put ip address to non of the interface not because I have seconday PIX, it is because trhe PIX was in multiple context. After I swtiched it back to single context and reboot, I can put ip address to one the interface and I tftp the flash back.
Thanks for your input anyway.
