Unity clock syncronisation
Answered Question
Jul 15th, 2008
hi, trying to setup secure encrypted integration between CUCM 6 and Unity 5.0 (UM) - the integration guide states:
'CautionThe Cisco Unity system clock must be synchronized with the Cisco Unified CM system clock for Cisco Unified CM authentication to function immediately'
How is this done - any step by step guides would be useful...Jag
Correct Answer by tim.giles about 8 years 3 months ago
Overall Rating: 3.5 (2 ratings)
thfergus Tue, 07/15/2008 - 07:46
Upon installation of a CUCM 6.x publisher, you encouraged to have is sync with an NTP source. A Unity 5.x server will synchronize with it's domain controller. If the Unity server is also functioning as a domain controller, then you can configure it to use the same NTP as used by the CUCM6.x publisher.
