server system requirement LMS3.0
Jul 15th, 2008
I'm planning to install LMS 3.0/3.01 on VMware ESX 3.0. The documentation does not specify the minimum requirement with less than 1500 devices . Is this the minimum requirement specification?
Intel Xeon with 2 CPU at 3.66Ghz and 4GB RAM memory and 8 GB swap space.
80GB Disk Space.
Joe Clarke Tue, 07/15/2008 - 08:33
It depends on the number of devices you are planning to manage, and the apps you plan to install from the LMS bundle.
Joe Clarke Tue, 07/15/2008 - 08:43
The VM must have at least 4 GB of RAM and 8 GB of swap with access to at least two CPU cores. The physical machine must have at least this hardware.
