Block Inside Network
Answered Question
Jul 15th, 2008
Hi, We have been using ASA for last ne year and its working fine, now can I block the inside machines that means 2 machines are available in inside zone now i want that first machine not able to access or communicate with second machine, is it possible becoz the traffic wont bypass through firewall when both communicate. Thanks
Correct Answer by Farrukh Haroon about 8 years 6 months ago
If both machines are in 'same subnet', then both will communicate 'directly' and will never each the firewall. You have the following options:
> Change the switch
> Change the network design
> Play around with some routes/proxy-arp
> NAT one of the machines on the firewall etc.
Farrukh
Overall Rating: 5 (1 ratings)
Farrukh Haroon Tue, 07/15/2008 - 09:03
You can use an access-list (VLAN or PORT) on the switch to block this communication.
Farrukh
nikuhappy2010 Tue, 07/15/2008 - 09:36
Here, the Switch is not managable and all switch are connected with inside interface of FW, now is it possible?
Correct Answer
Farrukh Haroon Tue, 07/15/2008 - 09:42
> Change the switch
Farrukh
