Applying a Service-Policy to an SVI w/HSRP
Jul 15th, 2008
Can it be done?
I'm trying to, on a pair of WS-C3560G-24TS switches running IOS c3560-ipservicesk9-mz.122-25.SEE2.bin, without success.
Each switch has a routed link to the core and are trunked together. They each have an SVI, Vlan302. The SVI's are configured as HSRP group 1, providing one fault tolerant gateway for Vlan302.
Is it possible to apply a service-policy to this vlan?
For Example:
int vlan302
service-policy input Packet-Tagging
policy-map Packet-Tagging
class Business_Critical
set precedence 3
class-map match-any Business_Critical
match access-group name ERP_traffic
Thanks for your replies!!!
royalblues Tue, 07/15/2008 - 10:04
If you are trying to set outbound service policy on the 3560, then unfortunately it is not supported on the above platform due to asic limitation
3560 supports only ingress service policies.
Narayan
Dean Weeks Tue, 07/15/2008 - 10:13
Sorry, I should have included this...
For Example:
int vlan302
set precedence 3
Collin Clark Tue, 07/15/2008 - 10:22
Narayan-
Do you know when the 3560 started supporting policies on SVI's?
