Cisco 800 VPN behind firewall
robbonner
I am looking to have my current Cisco 800 VPN box sit behind my firewall. Does anyone have the information on which ports I would need to forward to the box to have it continue to work as a VPN appliance?
Thanks in advance!
Hi It depends on what type of VPN you have...
For IPSEC vpn's you need = UDP 500 (also sometimes it may need UDP 4500 and 10000)
for PPTP vpn = TCP 1723
Hope this helps.
michael.leblanc
Level 4
Level 4
If you are not using UDP or TCP encapsulation of IPSec to get through a NAT process, then you would also need to include the IPSec encapsulation protocol(s) being used:
Encapsulating Security Payload is IP protocol 50.
Authentication Header is IP protocol 51.
... in addition to the port numbers specified by the other responder.
