ASA5540 outside and inside connected to same router routing issue
Jul 15th, 2008
I am trying to set up ASA for VPN. my network design is as follows:
both network and network are in the same router ASA is connecting to.
I have
route outside 0 0
route inside
route inside
route inside 0 0 tunneled
But when I try from ip to w/ vpn enabled. I get the following error message:
%ASA-6-110003: Routing failed to locate next hop for udp from NP Identity Ifc: to outside:
Any routing suggestion?
singhsaju Thu, 07/17/2008 - 11:47
As from your diagram network is located in outside zone .
Can you remove following routing statement and then check :
route inside
