syslog question (Catalyst 2950, IOS 12.1)
Jul 15th, 2008
Hello Everyone,
New to switches here, so please be kind if this is a dumb question!
Is there any way to configure the switch to output a message when the startup-config changes? For example, make some changes to the running-config, and then issue "copy run start" command.
vergeerf Wed, 07/16/2008 - 05:12
you can use the config-copy MIB or use LMS RME automated action (run script if CONFIG syslog message is generated)
ema2nochubank Wed, 07/16/2008 - 05:19
hi there,
thanks for your reply. the thing is we don't see anything about the changes in startup-config from the result of "sh logging".
we have tried all the logging trap levels. any idea?
