Jaime Valencia Tue, 07/15/2008 - 18:00
only if you look directly at the numplan table because there is no other way to do that.
javalenc
if this helps, please rate
Naveen Raj Janardhan Wed, 07/16/2008 - 05:16
Is the numplan table the xls file seen in the route plan report or is it at a different location?
Thanks Jamie for the information.
Jaime Valencia Wed, 07/16/2008 - 05:31
no, numplan is under the CCM DB in SQL
data for the route plan report comes from that table.
javalenc
