IP NAT outside causes VPN to fail
Daniel Voicu Tue, 07/15/2008 - 21:31
The reason is this: you redirect the ISAKMP port (UDP 500)
ip nat inside source static udp 172.16.3.200 500 wan.wan.wan.248 500 extendable
Change the port on the NAT statement and keep UDP 500 clear for VPN.
Please rate if this helped.
Daniel
