L2TP configuration
Jul 15th, 2008
Hello everyone,
I'm trying to configure L2TP tunneling between cisco 1841 and cisco 2811.
When I configure L2TP tunneling, I need to execute "pseudowire-class" command.
However, my cisco 1841 doesn't support the command.
The IOS release of this cisco 1841 is 12.4(19), and the feature set is "Advanced Security".
Do you know why the cisco 1841 doesn't support the "pseudowire-class" command?
smahbub Mon, 07/21/2008 - 11:55
The pseudowire-class command allows you to configure a pseudowire class template that consists of configuration settings used by all attachment circuits bound to the class. A pseudowire class includes the following configuration settings:
Data encapsulation type
Control protocol
Sequencing
IP address of the local Layer 2 interface
Type of service (ToS) value in IP headers
Check if all the configuration settings are done properly.
