PIX config-site to site and site to client.
Jul 15th, 2008
We are using IPsec b/w site to site (Bangalore A and US B).We need to configure Bangalore PIX for VPN Connection also from Bangalore A to Cheenai C (Site to client).What would be the configuration? Whether this PIX Version 6.3(4) will support.
The site to site configuration is as follows.
crypto ipsec transform-set strong esp-des esp-sha-hmac
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map BLR 20 ipsec-isakmp
crypto map BLR 20 match address 102
crypto map BLR 20 set peer 209.10.209.56
crypto map BLR 20 set transform-set strong
crypto map BLR interface outside
isakmp enable outside
isakmp key A3L791-10BLU-2 address 209.10.209.56 netmask 255.255.255.255
isakmp identity address
isakmp nat-traversal 20
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash sha
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
telnet 10.1.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
username xxx password xxx encrypted privilege 15
terminal width 80
Cryptochecksum:xxx
dhananjoy chowdhury Tue, 07/15/2008 - 22:18
  • Silver, 250 points or more
Hi Manjunath,
First of all I would suggest you to upgrade the IOS to atleast 7.0.
You can configure the both site 2site and client2site vpns on the same box. But be carefull when creating the crypto map for the remote vpn.
Here is an example of adding remote vpn config in the same FW with an existing site2site vpn.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807f9a89.shtml
Hope this helps.
Dhananjoy
