Unistallation of CCM 4.3
Jul 15th, 2008
Just wanted to check if the CCM needs to be reinstalled, is it possible to unistall it completely and then then install it again, rather then formatting the whole server and doing it.
If yes how?
Zin.Karzazi Wed, 07/16/2008 - 00:52
Short answer is no. You need to blow out the whole box and reinstall everything.
Jaime Valencia Wed, 07/16/2008 - 05:47
i totally agree with Zin
even though there is a procedure to try uninstalling it if you're willing to do it, it's best to rebuild the server from scratch than just reinstall CUCM
if this helps, please rate
