Multiple VMs to single CCM cluster
Jul 15th, 2008
hi all,
Is it possible to configure two vms (nevotek adagio & unity) to CCM 6.1.
As adagio is integrated with CTI ports configured on CCM.Will it be possible to install unity in the same cluster & use it using different group of CTI ports
Jaime Valencia Wed, 07/16/2008 - 05:52
unity does not use CTI ports if you're doing a SCCP integration and even with that, there should be no issue configuring a dual integration on CUCM
javalenc
if this helps, please rate
Tommer Catlin Wed, 07/16/2008 - 07:52
To add, if you are using Unity 5.x, you can also use SIP to connect Unity to CUCM. But the TSP and SCCP is the way to go.
