07-15-2008 10:40 PM - edited 03-11-2019 06:14 AM
Hi Friends,
I have installed cisco security manager 3.1.1 with RME version 4.0.5
I have problem while adding ASA 55xx devices in RME. I get the error
" CM0056 Config fetch failed for Bangalore ASA Cause: CM0204 Could not create DeviceContext for 9 Cause: CM0206 Could not get the config transport implementation for 147.183.224.5 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed. "
While checking I found the some of the RME packaged to be installed and I tried installing the packages but failed.
When i try to check the installation status in log file I get the error
" Problem with File /WEB-INF/screens/psu/ActivityLog2.jsp!!!835 "
Also I get the PIX & ASA image out of sync error.
Processing PIX 515E
No running image information in inventory.
Processing ASA
SWIM0013: Image Import Operation is not supported.
can anyone help me to solve this issues.
Chandru
07-21-2008 06:21 AM
CM0204:
Error message - Could not create Device Context for the device
Possible cause - Device package may not exist
Action to be taken - Check whether the required device packages are available in RME.
CM0206:
07-22-2008 01:11 AM
I could able to resolve the issue by updating the RME patches.
But I can't see the existing VPN's in security manager console after I import the devices from DCR. Can some one help to resolve the issue.
