Problem using Mozilla Firefox for service on CSS
Jul 15th, 2008
I have a problem with a CSS11503.
I have configured a content with a specified url for the tcp port 80.
If I use the browser Mozilla Firefox and I use the specified url (// all is on, but if I specify the url and the port 80 (// the CSS cannot reply.
If I remove the url this problem does not exist but I cannot do it in on stream.
Can someone help me, please?!
Gilles Dufour Wed, 07/16/2008 - 00:41
:80 is the default and normally should be omitted. A browser will not send the :80.
So, I suggest you do not configure it.
If you configure it, the CSS will want to see it.
csiracusa Wed, 07/16/2008 - 00:55
Hi Gilles,
sorry, but I cannot understand when you said
"So, I suggest you do not configure it." Where on the browser or on the CSS?!
I have to use on the browser because I have to do a penetration test with an application that use this one.
On CSS I have to configure it because it is mandatory, as you know.
And "If you configure it, the CSS will want to see it." where?!
Then, the CSS have to do a mapping of the port, so the client sent a request on port 80, but the real services are on dedicated port (like 2000x) specified on service section.
Thanks a lot for your suggestions!!!!
Gilles Dufour Wed, 07/16/2008 - 04:34
No, the :80 is not mandatory.
I believe it is even mandatory not to send it when using the default port.
So, the CSS should be configured without the :80 and your client should follow the HTTP spec and not send the default port with the url.
I know there was some improvement made in the code in this area, so you can try to run the very latest version and see if there is a difference.
If not, you will have the follow the recommandation I just gave you.
csiracusa Wed, 07/16/2008 - 05:01
I think that :80 could be mandatory in HTTP/1.1 (not in HTTP/1.0).
So the problem (and customer the alarm!!!!) is the compliance with some future version of browser.
What do you think about?!
