Can this Dial-peer used for both MGCP & SRST H323 DID in & SRST H323 out?
Answered Question
Jul 16th, 2008
Anyone who can inform me , is this dial-peer can used for both MGCP and SRST H323 DID in and SRST H323 out? or I have to split with 3 individial dial-peer,one is for MGCP , another one for SRST H323 DID in , and the last one for SRST H323 out?
dial-peer voice 1 pots
preference 1
destination-pattern 9T
incoming called-number .
direct-inward-dial
service mgcpapp
application MGCPAPP
port 0/0/0:15
Correct Answer by Ayodeji Okanlawon about 8 years 7 months ago
With SRST, I am afriad you have to configure all the dial-peers. There are no short cuts, I am afraid!
For incoming calls to work for srst you need only one command..
dialplan-pattern 1 9195014... extension-length 4
where 9195104 will be the beginning of the digits your telco sends to oyur gateway.
Below is an example of srst config...
call-manager-fallback
max-conferences 8 gain -6
ip source-address 10.10.10.1 port 2000
max-ephones 3
max-dn 3
For out going calls to work, you need to ocnfigure all the dial-peers that will specify call routing to all the required destinations similar to your Route patterns in callmanager.
This is the only way your srst can work
Overall Rating: 4 (3 ratings)
zhangjianping Wed, 07/16/2008 - 01:28
Thanks your feeback and the document you enclosed.
But I think I have configured the item for every mode, pls refer to the comment below, is that right?
My question is if each item is right, is that ok if I mix every item under one dial-peer to support both inbound/outbound in SRST mode and the normal call in MGCP mode?
destination-pattern 9T /for SRST Outbound/
incoming called-number . /for SRST inbound/
direct-inward-dial /for SRST inbound/
service mgcpapp /for MGCP in&out/
application MGCPAPP /for MGCP in&out/
port 0/0/0:15
Ayodeji Okanlawon Wed, 07/16/2008 - 01:38
Best practice is to do the following
1. Create a seperate pots dial-peer for incoming calls.
2. create a seperate pots dial-peer for outgoing dial-peers
example below:
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
progress_ind alert enable 8
progress_ind progress enable 8
port 0/0/0:15
These commands are required whether you are using srst or not and they will work for both srst and non srst situations
lastly depending on the IOS version you are using, you dont need the application mgcp or service mgcp under your pots dial-peer. ANd even if you do you only need one of them and not both
Example of mgcp config below
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.2.12
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config
controller E1 0/2/0
pri-group timeslots 1-8,16 service mgcp
interface Serial0/2/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
mgcp
mgcp call-agent 192.168.105.240 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
tone ringback alert-no-PI
direct-inward-dial
zhangjianping Wed, 07/16/2008 - 01:53
Thanks. I know what's your meaning.
But I DO want to know whether I can mix some dial-peer to one which includes SRST in , SRST out and MGCP in/out ? Just like the configuration I enclosed aboved.
As you know, normally, many dial-peers need to be configured for SRST, it's bored, I just want to simplify the configuration.
Is that OK?
Correct Answer
Ayodeji Okanlawon Wed, 07/16/2008 - 02:09
max-ephones 3
max-dn 3
