dialup on Cisco 1811 build in modem
Answered Question
Jul 16th, 2008
i am having problem, it connects and disconnects shortly. here is the config.
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer remote-name name
dialer idle-timeout 300
dialer string 13101310
dialer hold-queue 10
dialer-group 1
no peer default ip address
no cdp enable
ppp authentication pap chap callin
ppp chap hostname [email protected]
ppp chap password 0 wateen
exit
interface Async1
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async mode interactive
exit
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
logging on
loggin monitor
exit
terminal monitor
debug dialer
debug async state
debug ppp negotiation
Correct Answer by Richard Burts about 9 years 1 week ago
Usman
It looks like you are making some progress. In the output of 21-debug-ppp-auth.TXT authentication is failing on both sides. In the output of 21-debug-ppp-auth-nag.TXT (which is a bit later according to the timestamps) you are being authenticated successfully by the other device - but you are not authenticating the other device.
You are receiving a CHAP challenge from the other device using ID of lah-as5400-as1. To be able to authenticate successfully that device I would think that you would need a username configuration statement giving the name and password of that device.
Rick
Overall Rating: 4.5 (2 ratings)
a.alekseev Wed, 07/16/2008 - 02:27
  • Gold, 750 points or more
What did you see in the debugs?
Richard Burts Wed, 07/16/2008 - 03:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Usman
I agree that knowing what is in the debug output would be very helpful. I would be especially interested in the output of debug ppp negotiation. In addition I would suggest running debug ppp authentication. In my experience symptoms similar to what you describe are frequently the result of problems with authentication.
Rick
usmanjathol Wed, 07/16/2008 - 03:48
Router#ping 192.168.196.97
Sending 5, 100-byte ICMP Echos to 192.168.196.97, timeout is 2 seconds:
*Jul 16 11:40:13.775: As1 DDR: rotor dialout [best] least recent failure is also
most recent failure
*Jul 16 11:40:13.775: As1 DDR: rotor dialout [best] also has most recent failure
*Jul 16 11:40:13.775: As1 DDR: Dialing cause ip (s=10.10.0.1, d=192.168.196.97)
*Jul 16 11:40:13.775: As1 DDR: Attempting to dial 13101310
*Jul 16 11:40:13.775: CHAT1: Attempting async line dialer script
*Jul 16 11:40:13.775: CHAT1: no matching chat script found for 13101310
*Jul 16 11:40:13.775: CHAT1: Dialing using Modem script: d0efault-d0ials0cript &
System script: none
*Jul 16 11:40:13.775: CHAT1: process started
*Jul 16 11:40:13.775: CHAT1: Asserting DTR
*Jul 16 11:40:13.775: CHAT1: Chat script d0efault-d0ials0cript started.....
Success rate is 0 percent (0/5)
Router#
*Jul 16 11:40:42.435: CHAT1: Chat script d0efault-d0ials0cript finished, status
= Success
*Jul 16 11:40:42.435: As1 PPP: Async Protocol Mode started for 0.0.0.0
*Jul 16 11:40:44.435: %LINK-3-UPDOWN: Interface Async1, changed state to up
*Jul 16 11:40:44.435: As1 DDR: Dialer statechange to up
*Jul 16 11:40:44.435: %DIALER-6-BIND: Interface As1 bound to profile Di0
*Jul 16 11:40:44.435: As1 DDR: Dialer call has been placed
*Jul 16 11:40:44.435: As1 PPP: Using dialer call direction
*Jul 16 11:40:44.435: As1 PPP: Treating connection as a callout
*Jul 16 11:40:44.435: As1 PPP: Session handle[44000008] Session id[4]
*Jul 16 11:40:44.435: As1 PPP: Phase is ESTABLISHING, Active Open
*Jul 16 11:40:44.435: As1 PPP: No remote authentication for call-out
*Jul 16 11:40:44.435: As1 LCP: O CONFREQ [Closed] id 31 len 20
*Jul 16 11:40:44.435: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Jul 16 11:40:44.435: As1 LCP: MagicNumber 0x1EFEFE04 (0x05061EFEFE04)
*Jul 16 11:40:44.435: As1 LCP: PFC (0x0702)
*Jul 16 11:40:44.435: As1 LCP: ACFC (0x0802)
*Jul 16 11:40:44.527: As1 LCP: I CONFREQ [REQsent] id 1 len 24
*Jul 16 11:40:44.527: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Jul 16 11:40:44.527: As1 LCP: AuthProto PAP (0x0304C023)
*Jul 16 11:40:44.527: As1 LCP: MagicNumber 0xA6EB8E29 (0x0506A6EB8E29)
*Jul 16 11:40:44.527: As1 LCP: PFC (0x0702)
*Jul 16 11:40:44.527: As1 LCP: ACFC (0x0802)
*Jul 16 11:40:44.527: As1 LCP: O CONFNAK [REQsent] id 1 len 9
*Jul 16 11:40:44.527: As1 LCP: AuthProto CHAP (0x0305C22305)
*Jul 16 11:40:44.535: As1 LCP: I CONFACK [REQsent] id 31 len 20
*Jul 16 11:40:44.535: As1 LCP: ACCM 0x000A0000 (0x0206000A0000)
*Jul 16 11:40:44.535: As1 LCP: MagicNumber 0x1EFEFE04 (0x05061EFEFE04)
*Jul 16 11:40:44.535: As1 LCP: PFC (0x0702)
*Jul 16 11:40:44.535: As1 LCP: ACFC (0x0802)
a.alekseev Wed, 07/16/2008 - 03:55
try
interface Async1
async mode dedicated
and show again the debugs...
Richard Burts Wed, 07/16/2008 - 04:10
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
In looking at the debug output that you posted I see that most of the negotiation seems to be about disagreement about authentication. Can you post how the other end of the connection is configured - especially how it is configured for authentication?
Your router is configured to authenticate on callin. I see these messages in your logs:
and it makes me wonder what the remote end is expecting about authentication.
Rick
usmanjathol Wed, 07/16/2008 - 04:14
I am passing the dialup number, user id and password.
when i give same number, user and pwd on laptop modem it connects and i get ip and works fine.
i need to dial thru router and get ip and ping the auto assigned gateway thru router..
the nde debug with dedicated is attached
thanks a lot for help
a.alekseev Wed, 07/16/2008 - 04:22
Try to use PAP instead of CHAP.
ppp authentication pap callin
ppp pap sent-username PAPUSER password xxxx
usmanjathol Thu, 07/17/2008 - 00:44
Please check. Still not working.
I am attaching the running and debug.
Plz help
the same user id and pwd works fine when i connect thru laptop modem.
i want to establish a backup dialup settings. so when my WAN link goes down it should dial dialup and keep connected.
thanks
usman
Richard Burts Thu, 07/17/2008 - 04:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
The debugs that are in either of the files posted today are much less helpful than the previous posted ones. It would be helpful to see output of debug ppp negotiation. And it would be especially helpful to see output of debug ppp authentication.
But without seeing those debugs I have a suggestion. change:
to
Give it a try and let us know what happens.
Rick
Richard Burts Fri, 07/18/2008 - 03:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
The ppp authentication debug is helpful. It clearly shows that while you are configured to authenticate with PAP that the other end is configured to authentidcate with CHAP:
*Jul 18 03:57:42.843: As1 CHAP: I CHALLENGE id 1 len 34 from "lah-7206-vhg1"
*Jul 18 03:57:42.843: As1 CHAP: Unable to authenticate for peer
I would suggest that either you change your router to authenticate with CHAP or that you get the other side to accept authentication with PAP.
Rick
Correct Answer
Richard Burts Mon, 07/21/2008 - 03:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
Rick
usmanjathol Mon, 07/21/2008 - 18:37
Rick,
thanks for being with me.
I do not want to authenticate the remote device. Its a service provider network.. i just need to login there using the authentication they have give me..
I just need one way authentication.
any suggestions , what i need to change...
thanks
Usman
Richard Burts Mon, 07/21/2008 - 18:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
If you want the other device to authenticate you but you to not authenticate the other device then add the parameter "callin" to the authentication command. So you would configure:
ppp authentication chap callin
Rick
usmanjathol Mon, 07/21/2008 - 19:56
Rick,
I'll try this and get back to you in couple of minutes
usman
usmanjathol Mon, 07/21/2008 - 20:21
Hi Rick,
It worked... i am successfully in now and getting IP from other side and can ping my desired location.
Thanks a lot for your help and valued contribution.
my 2nd issue is the backup DDR
i'll come back with that soon.
Usman
Richard Burts Tue, 07/22/2008 - 03:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Usman
I am glad that my suggestions were able to help you to resolve your issue. If you have questions about DDR please post them, but I would suggest that you open a new discussion rather than continuing in this discussion. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that there was a successful resolution to the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
usmanjathol Tue, 07/22/2008 - 04:03
Thanks Rick
I really appreciate ppl like you helping ppl ..
excellent job and excellent forum...
thanks again
Usman
