WebView Localization makes Scheduler fail
Jul 16th, 2008
Hi all, when we schedule webview reports all we get in the resulting file is:
<br /><div class='normaltext'>File Not found: java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key it-it
I guess it has to do with the fact that WebView was installed in Italian, while the AW was installed in English. Does anybody know if there's a workaround other than uninstalling - reinstalling WebView?
Thanks in advance
irisrios Tue, 07/22/2008 - 08:11
The root cause behind this is that they run daily backups of the ICM DB but they store the backup file on the local drive that Webview is installed. This causes the drive to get full and thus, renders that drive useless. So store the backup files on a network drive rather than a mission critical server
