Pix 515: address pool assigned by radius
Jul 16th, 2008
I've a Pix515 ver 7.05 with a vpn client access.
I would to assign the address pool by a radius server. I've tried to confidure on my radius profile the following attribute
cisco-avpair="ip:addr-pool=miopool"
and on pix I've configured
ip local pool miopool 192.168.10.1 - 192.168.10.20
But this configuration doesn't work
The radius sends the attribute to pix but the pix ignores it and assigns to user the pool configured on the tunnel-group's definition.
What have i forget ?
Can you help me?
thank in advance
barbara.costant... Wed, 07/16/2008 - 08:09
Thanks for your suggestion, but
the command vpn-addr-assign aaa is the default
The pix seems to ignore the attribute because interprets it as an acl
The error is the following
User: 'pix', Unsupported downloaded ACL Entry: 'ip:addr-pool=mio-pool', Action: 'Ignoring'
It seems a syntax error.
barbara.costant... Thu, 07/17/2008 - 00:37
I've tried to modify the radius attribute from IP to Ipsec but in this case the pix doesn't show any error message, it ignores the attribute.
B.
Farrukh Haroon Thu, 07/17/2008 - 01:31
  • Red, 2250 points or more
Is it possible to post debugs here?
Farrukh
barbara.costant... Thu, 07/17/2008 - 05:27
These files contain the configuration and the debugs.
In the debug's file there are the follow data
- debug radius
- debug aaa authentication
- debug aaa authorization.
thanks b.
barbara.costant... Thu, 07/17/2008 - 05:35
....... I've tried to upgrade the pix's release from 7.0(7) to 7.2(4) but the behaviour is the same. It doesn't work ;)
barbara.costant... Wed, 07/23/2008 - 01:14
the last update..... I've inserted in the radius on user's profile the "class" attribute with the name of group-policy.
In this way any users have one different group-policy with address-pool and split-acl.
This is the only solution that seems to work fine with the pix.
Thank you for all your replies and suggestions
Barbara
Farrukh Haroon Wed, 07/16/2008 - 05:24
Did you put the "vpn-addr-assign aaa" commmand?
Farrukh
barbara.costant... Wed, 07/16/2008 - 23:40
Yes, I put the command, the "vpn-addr-assign aaa is default configuration and pix doesn't insert it in the running-config.
Thanks for all
Barbara
