Nokia Call Conect Licensing question...
Jul 16th, 2008
Hi Team,
There is two part.no in GPL
NOK-SCCP-CCM-01=
and
SW-CCM-UL-NOK=
What the difference?
Ok if i install Intellisync CallConect to the phone and buy NRB0050000 (Nokia part.no). What additional things i must buy to use Nokia Phone with CME?
Thank you!
Overall Rating: 4.5 (2 ratings)
cmaiolani Sun, 11/02/2008 - 03:05
Sorry,
i have purchased a NOK-SCCP-CCM-10 license.
My question is if i have to put the same code of twelve digit in every of ten Nokia Phone, or i have to insert it in some portal, to obtain ten different codes?
Thanks a lot.
pasimahone Sun, 11/02/2008 - 22:33
You have to use the same license code for every phone.
Br,
-Pasi-
Sushil Kumar Katre Mon, 11/03/2008 - 00:06
Hi Alexandr,
NOK-SCCP-CCM-01= is Cisco's part number which gives you Nokia Intellisync Call Connect 1.1 client software.
Along with this what you need is Cisco Communications Manager Licensing for it to
be used with Cisco Unified Communications Manager.
For use with Communications Manager
Release 5.x and higher, six DLU (Device License Units) are required for each Nokia Client.
LIC-CM-DL-10=
For use with Cisco Unified Communications Manager Release 4.x you need
SW-CCM-UL-NOK=
Single Cisco Unified Communications Manager
License for Nokia Eseries Dual Mode Phone
-> Sushil
krishnamurthy.mh Sat, 04/11/2009 - 02:06
Running UCM 6.1.2.
My Question is if i want to use the Nokia Intellisync Call Connect client with the CallManager, do i require license file from Cisco to integrate the Nokia Phone with UCM ?
cmaiolani Sat, 04/11/2009 - 02:41
if i have understand the question, you have to download from the same place wher you download yuor ICC client, the device package file for install it on CUCM 6.
In this way, when you will insert a new device, you will find in the list the device S60, that represent the NOKIA.
The only license you have to purchase is the NOKIA license that you insert on ICC.
When you define it in Call Manager, it takes six units.
Bye
krishnamurthy.mh Sat, 04/11/2009 - 06:01
Hi Costantino,
Thanks for you reply.
We are running UCM 6.1.2.
I need one more clarification, if i download the file from Nokia "cmterm-nokia_s60_2.0-sccp.cop.sgn" and in OS administration,the file will be installed through, Upgrade>install Upgrade and after installing do we need to restart the UCM OR any other necessary prerequesite for this installation. Because UCM is in production.
Let me any other procedure to install the file on UCM.
cmaiolani Sat, 04/11/2009 - 11:01
you have only to install succesfully the package from the Upgrade section of CUCM.
When it finished, you should try to create a new device and in the list there will be the "S60" device.
Bye.
