2600 routers
Jul 16th, 2008
I am building a home lab. I have 4 2620 routers and 4 3550 switches. My question is can I use one of this routers to access the other routers and switches rather that moving the console cable every time I access the other devices? Also can one of the routers be used as a frame relay switch? Some one had a diagram and configuration posted previously I just can't find it.
Paolo Bevilacqua Wed, 07/16/2008 - 03:24
  • Hall of Fame,
    Founding Member
Actually if you configure properly you can access everything from everywhere via telnet, no console cables are needed unless you lock yourself out of something.
And yes the router can be used as a basic frame-relay switch good for lab purposes.
please rate post if it helps!
a.alekseev Wed, 07/16/2008 - 03:27
  • Gold, 750 points or more
you'd better try dynamips.
http://www.ipflow.utc.fr/blog/
if you have IP connectivity so you can use telnet.
for the LAB environment
conf t
line vty 0 4
logg sync
no login
privilege level 15
Yes, you can. But you have to have serial cards and cables.
