Error loading flash: (Boot process failed)
Jul 16th, 2008
Does anyone know how to recovery from this 1130 AP. The flash is deleted. I tried to search the recovery steps but there is no document on this.
Thanks!
ap: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
tftp[5]: (read-only)
ap: help
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
clear_ether -- clear ethernet port statistics
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
dump_save_regs -- dump saved regs in OCM
etest -- test emac driver code
ether_init -- initialize ethernet port
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
init_pci -- initialize pci bridge
led_test -- cycle led patterns
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
reset_gpio -- reset gpio
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_baud -- set baud rates
set_gpio -- set gpio
set_sleep -- Pause (sleep) for a specified number of seconds
show_ether -- show ethernet port statistics
show_pci -- show pci setting
switch status -- report push button switch status
tar -- extract or listing a tar file
test ram -- read at address
tftp_init -- Initialize tftp file system
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
ap:
ap: boot
Loading "flash:/c1130-k9w7-mx.124-10b.JA/c1130-k9w7-mx.124-10b.JA"...flash:/c1130-k9w7-mx.124-10b.JA/c1130-k9w7-mx.124-10b.JA: magic number mismatch: bad
mzip file
Error loading "flash:/c1130-k9w7-mx.124-10b.JA/c1130-k9w7-mx.124-10b.JA"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap: dir
jegannmysore202 Wed, 05/28/2014 - 01:06
ap: boot
Loading ""...: permission denied
Error loading ""
