NIC teaming with ASA
Jul 16th, 2008
Can ASA do NIC teaming? For example, can I take both eth0 and eth1,
each NIC is 1Gbps each, and bond them into 2Gbps pipe?
The reason I am asking is because I have a customer running Checkpoint
Secureplatform NGx R65 and that the firewall can do NIC bonding. They
have 4 physical interfaces on the firewall but the interfaces have been
combined that the "outside" is of eth0 and eth1 and the "inside"
interface is of eth2 and eth3. The firewall is mainly used as backup
so high throughput is required but customer does not want to spend money
on 10G modules. They maxed out at 1.3Gbps so all they need is NIC teaming
of two 1G modules.
Can I do that with ASA? Thank you in advance.
Peter
a.alekseev Wed, 07/16/2008 - 04:07
  • Gold, 750 points or more
ASA doesn't support NIC teaming.
