UC and router 1861
Answered Question
Jul 16th, 2008
I have the following requirement:
IP telephony for 8 user, about 6 agents will be using simultaneously on PSTN network (approximately 5 incoming calls and one outgoing calls using head phones), voice mail optional
My solution is:
Cisco part no.
C1861-UC-4FXO-K9
1861, 8-user CME, CUE, Ph. Lic, 4FXS, 4FXO, 8xPOE, HWIC slot
Can it process four incoming calls and four outgoing calls through PSTN network simultaneously?
Also is there a part no. for 1861 router that has only CME?
Also for future how do I add redundancy to this router?
Thanks.
Correct Answer by paolo bevilacqua about 9 years 1 week ago
it could be better if you look at the UC520 8 users that is very similar to the 1861 but also has all the phone licenses included.
Since you're planning to have only 4 FXO lines, you can only do 4 calls, does not matter if incoming our outgoing.
Of course you can get a ITSP and do all calls over the internet.
It would be better if you take the model with BRI, that would give you more features and less trouble.
to have redundancy you would have to buy another units, in most cases that is just too expensive, so it's better to buy a good smartnet contract to be entitled to replacements.
Please rate post if it helps!
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Wed, 07/16/2008 - 04:28
  • Hall of Fame,
    Founding Member
