ciscoworks HUM mibs
francisco_1
Level 7
Level 7
Downloaded mibs from the cisco website, copied in to CSCOpx\hum\mibmanager\mibs and changed mibs file extnesion to obj and also did the same under the CSCOpx\hum\mibmanager\mibcomplier\mibs and rename file extension to my. none of the mibs appearing under HUM.
i'm i doing anything wrong?
what i need to mibs for eigrp, hsrp and temperature.
5 Replies 5
Joe Clarke
You need to actually load them using the HUM > Admin > Load MIB.
did that also. no success.
HUM is very particular about how it loads MIBs. Make sure that the MIB files are named the same name as their module, and make sure you have loaded all the required dependencies first. For example, for the CISCO-EIGRP-MIB, make sure your MIB file is named CISCO-EIGRP-MIB.my, and that you have already loaded the INET-ADDRESS-MIB.
extactly the issue here.
below are the mibs i got from http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-EIGRP-MIB#dependencies. i need the CISCO-EIGRP-MIB but cannot load in to HUM without loading the dependencies first. right? so which one should i load first and last?
MIB Name Version 1 Version 2 Dependencies
1. SNMPv2-SMI
2. SNMPv2-TC
3. SNMPv2-CONF
4. SNMPv2-MIB
5. IANAifType-MIB
6. IF-MIB
7. CISCO-SMI
8. INET-ADDRESS-MIB
9. SNMP-FRAMEWORK-MIB
10. RFC1155-SMI
11. RFC-1212 Non-Cisco MIB | Non-Cisco MIB | -
12. RFC-1215 Non-Cisco MIB | Non-Cisco MIB | -
13. SNMPv2-TC-v1 Non-Cisco MIB | Non-Cisco MIB | -
14. CISCO-EIGRP-MIB
SNMPv2-SMI
SNMPv2-TC
SNMPv2-CONF
SNMPv2-MIB
IANAifType-MIB
INET-ADDRESS-MIB
SNMP-FRAMEWORK-MIB
IF-MIB
CISCO-SMI
CISCO-TC
CISCO-EIGRP-MIB
