Marwan ALshawi Wed, 07/16/2008 - 05:07
can u clearify ur question what kind of gateways and what connectivity u want ??
Edison Ortiz Wed, 07/16/2008 - 05:24
A router can have 2 different default route/gateway on its configuration.
With this configuration, it will perform a 'per-session' load balancing towards both gateways.
In other words, a workstation may have a flow going towards gateway A and a different flow going towards gateway B.
HTH,
__
Edison.
festusimazenobe Wed, 07/16/2008 - 22:03
Hi Edison,
i have a server that i want to configure with two different pool of IPs with separate gateways, so i want to know if one router can be configured with the two different pool of IPs with separate gateways eg.(10.116.48.0/24 defaultgateway 10.116.48.1 and 10.116.49.0/24 defaultgateway 10.116.49.1)
festus.
Marwan ALshawi Wed, 07/16/2008 - 22:09
it could be achived ethier by a secondary ip address on the router interface or by doing subinterfaces like router-on-stick
