SRST with FXO to Hunt Group
Jul 16th, 2008
I am using CUCM 6.1 with SRTS to remote gateway.
The remote H323 gateway is using FXO ports, and in normal operation do a connection PLAR to a CUCM Hunt Group.
During SRTS, I would like the calls to ring to a single IP Phone. Is there a way to do this? Currently since using a PLAR to call manager DN, in SRST all incoming calls fail.
Tommer Catlin Wed, 07/16/2008 - 09:10
  • Green, 3000 points or more
You need to put in voice translations. Here is an example
voice translation-rule 100
rule 1 /\(.*\)/ /10000/
voice translation-profile voice
translate called 100
All calls coming in, ring extension 1000
Then the Translation rule is called "100"
Then we use the dial peer:
dial-peer voice 100 pots
translation-profile incoming voice
destination-pattern 9T
direct-inward-dial
port 0/0/0:23
In this case, we are using any POTS line use the translation profile incoming. The rest is just used for outbound.
Hope this helps!
