CVP PIM message after upgrading to 7.2.5
Jul 16th, 2008
  • Blue, 1500 points or more
So, we went from 7.2.4 to 7.2.5 and now I see this message in the PIM window after rereoute to alternate DNIS is envoked. Anyone seen something like this?
08:09:40 pg2A-pim4 Trace: Dialogue::FromVRU_EventReport:
VRU->PG: Service Control Message (= Message Type 47); Message Length 16 bytes
Event Report (= Subtype 10); DialogueID: (174) 000000ae;
SendSeqNo: (4)00000004
Event Code: (3) No Answer
08:09:40 pg2A-pim4 Trace: Dialogue 174: UnrecoverableFailure Unspecified Failure (15) from Dialogue::FromVRU_EventReport
08:10:19 pg2A-pim4 Trace: Dialogue::FromVRU_EventReport: No CONNECT request pending.
Event Report (= Subtype 10); DialogueID: (176) 000000b0;
08:10:19 pg2A-pim4 Trace: Dialogue 176: UnrecoverableFailure Unspecified Failure (15) from Dialogue::FromVRU_EventReport
Thank you,
David
Riccardo Bua Wed, 07/16/2008 - 06:50
  • Cisco Employee,
Hi David,
how are you doing the reroute? It looks like there is a no answer reported back on a dialogue already cleared up, suspect you might have some ghost calls objects as well.
Riccardo
david.macias Wed, 07/16/2008 - 07:10
The re-route is done theough CVP 4.0.2 H.323 using the altenate dnis feature.
david
Riccardo Bua Wed, 07/16/2008 - 08:04
  • Cisco Employee,
Hi David,
I couldn't locate any internal report on this.
Would you please raise a TAC SR for follow-up?
Riccardo
