PIX slow with IPS
Jul 16th, 2008
I have 2 Cisco PIX ver 6.3 (one with UR and another with FO). I have also a Tippingpoint IPS (Unity 400) which is behind the PIX. The three segments of the IPS are physically connected to PIX1 (UR), one of which is to an inside network. One segment of the IPS is connected to PIX2 (FO) which is another connection to the inside network.
My questions:
1. is physical connection from all segments of the IPS to PIX1 enough for any traffic to pass through the IPS whether PIX1 or PIX2 is active?
2. when PIX1 is active, traffic is too slow to the inside network, why?
smahbub Tue, 07/22/2008 - 08:13
PIX console response is very slow if there are more uauth/sec.
Can you provide the more information about the network which will help us to understand the issue better and resolve the same.
mulugetash Wed, 07/23/2008 - 01:43
thanks for your response, but I think I have described the connectivity well ( the part more important to the issue). If there is any specific info that you need, I'll describe it.
