Discover Codecs used in a Wan Link
Jul 16th, 2008
Hi guys,
I'm using a Single CiscoCallManager (Centralized) with some remote offices using IP Phone or IP Communicator via WAN..
Is there any way to me see what are the Codecs used by the clients ??
Basicaly I wanna identify how many codecs G.729 and how many codecs G.711 are in now in the wan links
Thanks in Advanced,
My Best Regards,
Andre Lomonaco
irisrios Tue, 07/22/2008 - 14:13
The codec that Unity is currently using is stored in HKLM\Software\Active Voice\MIU\1.0\Initialization\Default Wave Format.
The number in "Default Wave Format" corresponds to one of the "Wave Format x" keys.
You can identify the codec that is used for a call by looking at the trace file.
