Uninstall of LMS & ReInstall
Jul 16th, 2008
Hi All,
I want to uninstall the LMS & again Install the same in the same server.Do I need to format the server & reinstall windows server itself before installing LMS.
Does the old registry entries will create any problem if I will not format the server?
Thanks in advance
Sachi
David Stanford Wed, 07/16/2008 - 06:40
You can uninstall LMS via the Uninstall Option in under Program Files or via Add/Remove Programs.
I would also suggest after doing this you run the clean_system.exe (if you have it)
Unless there is something wrong with the system I wouldn't think there is a need to format and reinstall the OS.
Also have a look at:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc07cae/0#selected_message
