ASA 5505 basics
Daniel Voicu Wed, 07/16/2008 - 08:50
  • Silver, 250 points or more
ASA is not capable of Spanning Tree, nor should it, since it does not forward broadcasts packets.
The ASA interface will be configured as trunk, while for each VLAN you will configure subinterfaces. Assign one VLAN ID per interface.
The IP of the ASA on each subinterface will be the default gateway for the devices on that subnet.
interface GigabitEthernet0/1
description "Trunk Connectivity with SW"
speed 100
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.100
vlan 100
nameif VLAN100
security-level 80
ip address xxxxxxx
interface GigabitEthernet0/1.200
vlan 200
nameif VLAN200
security-level 70
ip address xxxxxxx
interface GigabitEthernet0/1.300
vlan 300
nameif VLAN300
security-level 60
ip address xxxxxxx
By default no routing is done between VLANs.
An example with VLANs and remote access VPNs:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806ab788.shtml
BTW, ASA does not have Native VLAN support. So if you need VLAN 1 for some reason, you need to create a subinterface for it.
Please rate if this helped.
Daniel
while configuring I changed the admin 192.168.1.1 address to 192.168.10.4 (that is showing under VLAN 1)
then I've configured 3 additional VLANS for each of my LAN networks - VLANs 10, 11, 12
for VLAN 11 & 12 I could configure an IP address using 192.168.10\11.x
VLAN 10 won't let me configure an IP since it is already configured on VLAN1
does it mean I have to remove the management IP and switch it back to 192.168.1.1? if so, how will I access it via LAN?
I did see few posts that said 5505 do not support sub-if, is it possible?
ASA# sh ver
Cisco Adaptive Security Appliance Software Version 7.2(3)
Device Manager Version 5.2(3)
Compiled on Wed 15-Aug-07 16:08 by builders
System image file is "disk0:/asa723-k8.bin"
Config file at boot was "startup-config"
OGASA up 1 day 16 hours
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0 : address is 0021.55d8.e84d, irq 11
1: Ext: Ethernet0/0 : address is 0021.55d8.e845, irq 255
2: Ext: Ethernet0/1 : address is 0021.55d8.e846, irq 255
3: Ext: Ethernet0/2 : address is 0021.55d8.e847, irq 255
4: Ext: Ethernet0/3 : address is 0021.55d8.e848, irq 255
5: Ext: Ethernet0/4 : address is 0021.55d8.e849, irq 255
6: Ext: Ethernet0/5 : address is 0021.55d8.e84a, irq 255
7: Ext: Ethernet0/6 : address is 0021.55d8.e84b, irq 255
8: Ext: Ethernet0/7 : address is 0021.55d8.e84c, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 20, DMZ Unrestricted
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 25
WebVPN Peers : 2
Dual ISPs : Enabled
VLAN Trunk Ports : 8
This platform has an ASA 5505 Security Plus license.
Serial Number: JMX1221Z07S
Running Activation Key: 0xce06625a 0xa8d68c50 0x8c1055b0 0x9030f02c 0x8308b7a9
Configuration register is 0x1
Configuration last modified by enable_15 at 10:58:54.944 EDT Wed Jul 16 2008
