Configuring firewall for Cisco 851W
Jul 16th, 2008
I just sold a client a Cisco 851W and he brought it back because is having problems configuring it. I have configured the same device for others clients without a problem.
I'd reset the device back to manufacture setting, followed all steps as per the user guide. When tried to configure “Basic Firewall” at the end I got the following error at the command delivery status:
Submitting 238 commands, please wait…
Class-map type inspect imap match-any sdm-app-imap
Error detected at this command. Click ok
NOTE: ISP Cable (dynamic IP)
sirdudesly Wed, 07/16/2008 - 15:07
does it work if you don't do IMAP filtering (you can remove it from the list of inspected protocols in SDM)
virgild99 Sat, 09/20/2008 - 03:46
I am having a similar issue. Did you find a solution?
