Max-reserved-bandwidth
rll3
Has anyone ever used this command on an interface for strict priority and CBWFQ?
6 Replies 6
mounir.mohamed
Level 7
Level 7
If you need to allocate more than 75 percent for CBWFQ and IP RTP Priority, you can use the this command, because the sum of all bandwidth allocation on an interface should not exceed 75 percent of the available bandwidth on an interface. The remaining 25 percent of bandwidth is used for overhead, including Layer 2 overhead, control traffic, and best-effort traffic.
Best Regards,
Mounir Mohamed
Here is an example, below we have 3 different classes (HTTP/FTP/ICMP)in addition to the default class, i will allocate 500k for each class and only 44k for the default class,
since CBWFQ can not allocate more than 75% of the interface bandwidth the above bandwidth allocation doesn't comply with default bandwidth of serial interfaces which is 1544 (1544x25/100=386 so 1544-386=1158) so 1158 is the maximum available bandwidth for allocation on this interface, so the router will never accept policy-map with bandwidth over than 1158 unless we use max-reserved-bandwidth command.
PE1#conf t
PE1(config)#class-map http
PE1(config-cmap)#match protocol http
PE1(config-cmap)#class-map ftp
PE1(config-cmap)#match protocol ftp
PE1(config-cmap)#class-map icmp
PE1(config-cmap)#match protocol icmp
PE1(config)#policy-map qos
PE1(config-pmap)#class http
PE1(config-pmap-c)#bandwidth 500
PE1(config-pmap-c)#class ftp
PE1(config-pmap-c)#class icmp
PE1(config-pmap-c)#class class-default
PE1(config-pmap-c)#bandwidth 44
PE1(config-pmap)#int s2/1
PE1(config-if)#service-policy output qos
I/f Serial2/1 class icmp requested bandwidth 500 (kbps), available only 158 (kbps)
PE1#show queueing int s2/1 | inc Bandwidth
Available Bandwidth 1158 kilobits/sec
PE1(config-if)#max-reserved-bandwidth 100
PE1(config-if)#do show queueing int s2/1 | inc Bandwidth
Available Bandwidth 1544 kilobits/sec
Available Bandwidth 0 kilobits/sec
Best Regards,
Mounir Mohamed
the maximum reserved bandwidth refers to the sum of resources used by CBWFQ w/o LLQ not to a single class.
To be noticed that not all Cisco router platforms really use this concept (have an implicit system queue for routing protocols traffic etc)
For example on C7500 and GSR 12000 I remenber we had to allocate resources = BW for the routing protocols traffic and there isn't a control at 75% percent of bandwith.
So the command can be used to leave BW to user traffic on a high speed links where 25% of BW is too much for overhead.
Hope to help
Giuseppe
Joseph W. Doherty
Haven't had much need for it when later IOS versions supported percentages and/or remaining percentages.
How do you mean?
Before class percentages was a feature, you had to remember not to allow the combined explicit class bandwidths to exceed 75% of the link's bandwidth, unless you modified max reserve. With percentages, a bit easier since you only have to keep from exceeding 75% without referencing the link's bandwidth. With remaining percentages, you don't even need to account for reserve percentage, although it's still there.
