Problems with database replication: Publisher vs subscriber ( CCM 6.1.2)
Jul 16th, 2008
Hi all:
I was changing up the IP of mi CCM 6 cluster (publisher and a subscriber), but i see that doing that don't works wright, i decided to undo the changes that i done.
But now with the same configuration than before the publisher don't detects ok the subscriber.
In the subscriber i watch that the database is replicated but i watch it in my CM group both (publisher and subscriber).
I have the same parameters in my publisher.
But when via CLI in the publisher i perform an "show network cluster" it only appears my publisher and not my subscriber.
But in CLI doing the same instruction i obtain the publisher and ther subscriber.
What can i do?
How can i do to replicate correctly the database publisher in my subscriber.
Also when i execute "utils dbreplication status" in my publisher i obtain this response:
This command reads and writes database information from all machines and will take quite some time...please be patient.
-------------------- utils dbreplication status --------------------
Status cannot be performed when replication is down on the publisher, or on a cluster with a single active node; aborting replication status check operation
Output is in file cm/trace/dbl/sdi/ReplicationStatus.184115.out
Thanks in advance.
If you need more detail dont hesitate an Please tell me.
Ayodeji oladipo... Wed, 07/16/2008 - 09:02
Can you first of all check that the subscriber is still on your publisher...
Go to CCMadmin>system>server click on find.
Check to see that the subscriber is there and it has the correct ip address
