Incorrect time displayed on Ip phone
Jul 16th, 2008
Incorrect time displayed on Ip phone, have checked the time on CCM , it is correct. also the PC & Ip phone time is different. what needs to be done to have the ip phone display the time as the PC.
Tommer Catlin Wed, 07/16/2008 - 09:34
  • Green, 3000 points or more
Time zones in your device pool for the IP phone?
taraagarwal Thu, 07/17/2008 - 12:10
I have checked that too, also i have checked the NTP setting on the Gateway, they are correct. Is there some other place I need to check as the clock is 6 min fast only on the ip phones & not on the PC.
honniesr Wed, 07/16/2008 - 15:11
can you be more specific on what "different" means?
-Do you mean it's off by an hour exactly?
-Is it off by some other increment of time, like 45 minutes
If it's off by an hour (or some other increment of hours), probably a timezone issue.
