CME 4.1 to CUCM 5.1 SIP Trunk
Answered Question
Jul 16th, 2008
I have setup a sip trunk between my call manager and cme. I can call any phone from CUCM to the CME. When I try to place a call from CME to CUCM I am getting a fast busy. Here is by SIP Trunk on the CME side
dial-peer voice 1003 voip
destination-pattern 393
session protocol sipv2
session target ipv4:x.x.x.x
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
no vad
transfer-system full-consult
transfer-pattern .T
transfer-pattern 8...
transfer-pattern 128..
transfer-pattern 168..
I currently have the destination setup to try and call 1 specific phone for troubleshooting. On my CUCM side I have CSS set, Destination Address, MTP Preferred Origination Codec 711ulaw. Any ideas?
Correct Answer by paolo bevilacqua about 8 years 9 months ago
Just noticed you have "session transport tcp". Please remove that to leave the default of UDP.
Overall Rating: 5 (1 ratings)
Ayodeji Okanlawon Wed, 07/16/2008 - 09:30
  • Cisco Designated VIP,
    2017 IP Telephony
Please check the following:
1. MRGL that yout sip trunk is assigned has a software MTP in it
2. The CSS on the inbound calls on your sip trunk has the partiton of your ip phones in it
wbarren Wed, 07/16/2008 - 09:40
I have confirmed that the SIP trunk:
MRGL has a software MTP in it
CSS for inbound calls is in the partition of my phones.
paolo bevilacqua Wed, 07/16/2008 - 12:46
  • Hall of Fame,
    Founding Member
Hi, "393" doesn't seem right as destination-pattern. Suppose CM extensions all start with 3 and are four digits, "3..." would be right.
In any case, take "debug ccsip message" with "term mon" when calling. That will show numbers and causes.
wbarren Wed, 07/16/2008 - 16:23
All the ext on the CUCM side are 3 digits. I have the destination-pattern set for 393 because I was testing with 1 extention for troubleshooting.
paolo bevilacqua Thu, 07/17/2008 - 01:08
  • Hall of Fame,
    Founding Member
Then collect the debug trace as mentioned above.
Correct Answer
paolo bevilacqua Thu, 07/17/2008 - 01:50
  • Hall of Fame,
    Founding Member
paolo bevilacqua Thu, 07/17/2008 - 05:24
  • Hall of Fame,
    Founding Member
Thanks for the appreciation and good luck!
