/31 mask a good idea?
Jul 16th, 2008
Is anyone using a /31 mask on point to point links or uplinks between layer 3 switches? Is there any downside or gotchas? I'm planning on running layer 3 all the way to my access switches and using routed ports to connect the access to the distribution. A /31 mask would help conserve ip addresses, right?
thanks
Overall Rating: 5 (1 ratings)
Hi There
To the best of my knowledge a /31 netmask is not possible.
The smallest subnet possible is a /30 which yields 2 usable IP addresses along with the broadcast address of the subnet and the subnet number. This is what is recommended for a point to point link.
I think I remember reading somewhere about an RFC that was in the experimental stage which would allow a /31 mask (though I may be dreaming), but I have never heard of it being released for use.
I have seen instances where errors were made in configurations and either the subnet mask or the subnet number was assigned to a host and it appeared to work, but I think that this would be frowned upon in a live production network.
Best Regards,
Michael
burleyman Wed, 07/16/2008 - 13:01
While you are correct it can be done does it make it a "good idea".....Just because I could pierce my tongue 100 times does not mean it is a "good idea" :-)
Unless you have a shortage of IP addresses I would not introduce this.... just my Half-Penny (was two-cents but you know with the economy and gas prices).
Mike
autobot130 Wed, 07/16/2008 - 14:58
/31s are awesome. it saves IP space! The problem is its not interroperable with other vendors. Works on newer code.
sirdudesly Wed, 07/16/2008 - 15:09
saves IP space... if you're using it internally you more than likely have enough space anyway :P
DARYLE DIANIS Fri, 07/18/2008 - 07:17
thanks everyone for letting me know what you think. I'm going to try the /31 in a test environment and see if I like it. I am on a lan and do have plenty of addresses and of course, we're an all Cisco shop, so interoperability won't be a problem.
thanks again
