BGP Filtering: route-map or prefix-list
Jul 16th, 2008
I'm curious about best practices regarding the usage of route-maps or prefix-list in the bgp config.
Some examples i've seen apply a prefix-list directly to a neighbor, others use a route-map.
I can't tell if there is a benefit one way or another.
Examples:
prefix-list applied to neighbor:
http://www.cymru.com/Documents/secure-bgp-template.html
prefix-list applied to route-map applied to neighbor:
router bgp 100
network 171.60.0.0
network 172.60.0.0
neighbor 200.69.232.70 remote-as 200
neighbor 200.69.232.70 route-map set-as-path out
route-map set-as-path 10 permit
match address 1
set as-path prepend 100 100
route-map set-as-path 20 permit
match address 2
access-list 1 permit 171.60.0.0 0.0.255.255
access-list 1 permit 172.60.0.0 0.0.255.255
access-list 2 permit 0.0.0.0 255.255.255.255
from http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfbgp.html#wp1040707
Thanks!
-Jeff
milan.kulik Wed, 07/16/2008 - 12:06
IMHO, prefix-list just permits/denies prefixes while route-map can manipulate/change BGP attributes (local preference, MED, as prepend, etc.)
And to be precise, route-maps are matching as-path or ip access-lists, not prefix lists.
BR,
Milan
