Packet drops on Next hop Serial IP
Jul 16th, 2008
Hello all,
I have a problem with one of my frame relay circuit.
Im not seeing any errors on the physical link , Im getting gud response when i ping the LAN ip ranges on both the side.But my question here is when I ping the Serial Ip's of this Frame relay circuit Im getting packetdrops for every single response , like below
Sending 10, 100-byte ICMP Echos to 172.25.160.85, timeout is 3 seconds:
Success rate is 50 percent (5/10), round-trip min/avg/max = 8/18/44 ms
Any clue ??
sundar.palaniappan Wed, 07/16/2008 - 12:00
  • Green, 3000 points or more
Raghavan,
Typically, every other packet drop could be a result of a bad link when traffic is load balanced across multiple paths. Can you post the output of 'show ip route 172.25.160.85' from the router that you were pinging. As far as you being able to the LAN IP without packet drop is it using the same path? It would help if you can describe your network setup.
Sundar
vsraghav123 Wed, 07/16/2008 - 12:26
Thanks for the reply..
We have only single link connected between these 2 sites ..one end is the framerelay and the otherend is ATM. As i mentioned earlier when i ping the LAN IP range the response is gud and it takes the same WAN path to reach it ...below is the config for your view.....
interface ATM4/0.51 point-to-point
bandwidth 1024
ip address 172.25.160.85 255.255.255.252
ip mtu 1500
ip pim sparse-mode
ip multicast ttl-threshold 16
ip multicast boundary MC_Med
no snmp trap link-status
pvc 1/51
vbr-nrt 1272 636
oam-pvc manage
max-reserved-bandwidth 100
service-policy output Q-ATMsi
interface Serial0.51 point-to-point
bandwidth 1024
ip address 172.25.160.86 255.255.255.252
ip accounting output-packets
ip pim sparse-mode
no ip mroute-cache
frame-relay interface-dlci 51 IETF
class QPM_Q-FRsi-1024-512
sh ip route 172.25.160.85
Routing entry for 172.25.160.84/30
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 200
Routing Descriptor Blocks:
* directly connected, via Serial0.51
Route metric is 0, traffic share count is 1
please let me knwo if you need more info ..
sundar.palaniappan Wed, 07/16/2008 - 12:31
"service-policy output Q-ATMs" - Are you doing any strict policing under the policy map? Can you remove the service policy and try the pings or post the QOS configuration.
vsraghav123 Wed, 07/16/2008 - 12:35
class-map match-any Q1
match ip precedence 1
class-map match-any Q3
match ip precedence 3
class-map match-any Q5
match ip precedence 5
class-map match-any Q6
match ip precedence 6
policy-map Q-ATMsi
class Q6
bandwidth percent 4
random-detect
class Q5
priority percent 30
class Q3
bandwidth percent 35
random-detect
class Q1
bandwidth percent 1
random-detect
class class-default
bandwidth percent 30
random-detect
yes we do removed the QOS .. but still the same .. and we didnt noticed any drops in the policy map.
sundar.palaniappan Wed, 07/16/2008 - 12:45
What does 'show ip route 172.25.160.86' show from the ATM router.
Also can you post the configuration of class QPM_Q-FRsi-1024-512 from the Serial side.
vsraghav123 Wed, 07/16/2008 - 12:51
sure ...here it is ...
sh ip route 172.25.160.86
* directly connected, via ATM4/0.51
QOS on Frame relay end
policy-map QPM_Q-FRsi-1024-512
class QPM_Q6
bandwidth percent 4
random-detect
class QPM_Q5
priority 153
class QPM_Q3
random-detect
class QPM_Q1
bandwidth percent 1
random-detect
class class-default
random-detect
map-class frame-relay QPM_Q-FRsi-1024-512
frame-relay cir 1021000
frame-relay bc 10300
frame-relay mincir 512000
frame-relay adaptive-shaping becn
service-policy output QPM_Q-FRsi-1024-512
sundar.palaniappan Wed, 07/16/2008 - 13:05
Interesting.. If you aren't seeing drops on the policy map and have already tried testing without QOS configuration on both ends then can you enable 'debug ip icmp' on the ATM router and do the ping from the far end and see if all the packets make it across the FRASI circuit. This should help narrow the problem to the circuit.
vsraghav123 Wed, 07/16/2008 - 13:13
Okies , I wil try debugging sometime in the late nite after business hours .... do we have any other option to check in the meantime
sundar.palaniappan Wed, 07/16/2008 - 14:00
Everything looks good on your side. Have seen issues similar to this on frasi circuits. It's possible telco may be load balancing (layer 2) on their backbone. Ask them to bounce the PVC during the maintenance window and see if that makes difference. You may want to do the testing I had suggested earlier before you do that.
Sundar
a.alekseev Wed, 07/16/2008 - 14:19
  • Gold, 750 points or more
do you have the same on both sides?
did you try to ping with different source ip address?
vsraghav123 Wed, 07/16/2008 - 14:23
yes ..im getting this packet drops on both ends ... I did a extended ping with source as the WAN IP ..
vsraghav123 Wed, 07/16/2008 - 15:31
I dont see it to be a problem with IP CEF , Since by LAN packets hit my router and take the same path and moreover its my directly connected interface where im seeing this drop ...
Is there any thing we need to look more on the ATM-Frame Internetwork connection , but i do have same kind of configuration to some other sites which are running fine.
And due to this Im not seeing any impact in my network , but still wanted to know what exactly causing this packet drop.
milan.kulik Wed, 07/16/2008 - 23:05
  • Red, 2250 points or more
isn't there some Control Plane Protection/Policing configured on your router?
BR,
Milan
vsraghav123 Thu, 07/17/2008 - 07:02
Hey all , We just bounced the Link once ..which solved the problem :-) , Thanks for your help !!!!
sundar.palaniappan Thu, 07/17/2008 - 09:37
Glad to hear it's working now. If you bounced the interface and it started working then it very well may be due to an IOS bug. If the problem keeps repeating itself you may want to research for bugs on that code.
vsraghav123 Thu, 07/17/2008 - 09:52
Sure sundar ... will do that ... thanks once again for ur help !!!
