CUCMBE 6 - weird things happening
Answered Question
Jul 16th, 2008
A phone call goes to Unity Connection Auto Attendant, and is forwarded to a users extension via the dial by extension rule. While the phone is ringing, every phone in the office chimes and at the bottom of the display it says
Voicemail -> Username
Any idea where i might begin to look for this?
Correct Answer by Jaime Valencia about 8 years 9 months ago
you probably have configured the pickup group notification, might be a good place to start looking
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
allenelson Wed, 07/16/2008 - 12:42
ok.. i just realized it does it when you dial extension to extension also. hah.
anyone know how to turn this off?
Correct Answer
Jaime Valencia Wed, 07/16/2008 - 13:15
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
allenelson Wed, 07/16/2008 - 18:16
wow, i think you're dead on. i turned it on earlier and wasn't sure exactly what it was. i figured it would do something when you hit the pickup softkey. thanks a bunch.
