CUE voicemail issue
Answered Question
We have an issue with CFNA to CUE voicemail, searching around NetPro I found many users with similar issues but nothing we tried so far solved the problem.
The router is running CUE 3.1.2, CME 4.3 and IOS 12.4(15)XZ. Users can access mailboxes normally.
If I call from an inside extension to another extension and wait for CFNA timer (set to 10 sec) I get a message from our local telephony operator saying that the number doesn't exists - which means that CME is forwarding the call to the PSTN instead of voicemail (?). If I call from a external number to inside the company and wait for CFNA timer to forward the call I just get a busy tone.
router config:
voice translation-rule 1
rule 1 /^021/ /014/
rule 2 /^023/ /014/
rule 3 /^025/ /014/
rule 4 /^015/ /014/
voice translation-profile outcalls
translate called 1
dial-peer voice 1 pots
translation-profile outgoing outcalls
destination-pattern .T
port 0/0/0:15
dial-peer voice 2 pots
incoming called-number 27..
direct-inward-dial
dial-peer voice 3 pots
destination-pattern 2749
port 0/1/0
dial-peer voice 100 voip
destination-pattern 2747
session protocol sipv2
session target ipv4:10.10.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 101 voip
destination-pattern 2748
codec g711ulaw
no vad
telephony-service
load 7912 CP7912080003SCCP070409A
load 7920 cmterm_7920.4.0-03-02
max-ephones 16
max-dn 192
ip source-address 10.10.0.1 port 2000
service dnis dir-lookup
timeouts interdigit 3
timeouts ringing 60
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 5133732... extension-length 4
voicemail 2747
max-conferences 8 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jul 16 2008 16:34:45
ephone-dn 146 dual-line
call-waiting ring
number 2732
pickup-group 1
call-forward noan 2747 timeout 10
no huntstop
Correct Answer by Chad Stachowicz about 8 years 11 months ago
There is a well known bug with using CUE + Dial-plan pattern command.
What it does is translate all calls, therefore your dial-peer to unity actually looks like
5133732747 and its not hitting because your forwarding to 2747 to resolve do this!
voice translation-rule 10
rule 1 /513373\(2...\)/ /\1/
voice translation-profile to-cue
translate called 10
translate redirect-called 10
translate calling 10
now change your dial-peer to this!
translation-profile outgoing to-cue
destination-pattern 5133732747
codec g711ulaw
no vad
destination-pattern 5133732748
codec g711ulaw
no vad
dial-peer voice 102 voip
codec g711ulaw
no vad
dial-peer voice 103 voip
codec g711ulaw
no vad
Now incoming from the PSTN should have answered, please check to make sure the pilot number is set to the correct 4 digit number in CUE.
HTH, please rate useful posts!
Chad
Overall Rating: 5 (1 ratings)
Correct Answer
Chad Stachowicz Wed, 07/16/2008 - 23:06
  • Silver, 250 points or more
translate called 10
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
Chad
Chad Stachowicz Thu, 07/17/2008 - 08:24
I am not sure there is a bugID because i think the way dial-plan pattern works thats just a nasty side effect. You can also make an incoming voice-translation rule and translate incoming calls with that, and then remove dial-plan pattern! This is also acceptable!
Chad
