Removing Interop Mode 1
Jul 16th, 2008
I need to disable Interop Mode 1 after retiring McData switches. Can someone tell me what is the cli sequence to return the MDS 9000 series to default/native interop mode?
Thanks in advance!
tblancha Wed, 07/23/2008 - 08:15
do these commands for vsan X:
config t
vsan database
no vsan X interop 1
This will put it back in default mode.
chunkmunky Fri, 07/25/2008 - 01:36
After running the command against the vsan won't you have to suspend it to make the change active.
donhoover Tue, 07/29/2008 - 12:06
At one time, there was a white paper that went through a detailed migration of McData -> Cisco, including adding Cisco to the SAN in interop mode 1, and removing the McData.
I can't find it at the moment though.
Trending Topics: Storage Networking
